Can someone help me , i have issues speaking through the camera , I have remove the battery, and reinstall it to the base station and nothing since to work, I appreciate if someone help thank you
What device are you using ??
have you tried an external mic?
Have you tried via a computer ( https://arlo.netgear.com ) to see if it is the system or phone/device.
Seems the many new iphones running ios 12x are seeing issues, but need to know what your using and wha you have tried already for a good answer
Well I have a ifhone and I don’t think this could be the issue, because the others cameras work perfectly it just one camera that it seems not to be working, speaker ,
And what do u mean by the external mic?
If it is only ONE camera, contact Arlo support as that camera may have an issue.
As to external mic... BT mic or ear buds with mic in cable
