Arlo pro 2 not detecting motion
  • 4704 Views
dkbecker
One of my two cameras is not detecting motion., Motion detecting test doesn’t work either. Could this be a defective camera, if so, how do I get a replacement?
Rob198690
Has anybody had a problem with their camera not detecting motion when plugged into ac power? As soon as it’s back on battery power it works perfectly but when plugged in it doesn’t work at all. Activity zones are disabled and even using the motion detection test in the app does not work.
Dannybear
Yes been there, have no real answers but have you tried setting up a activity zone for the camera when on external power to see if it works the way it should? I have seen the zone behave the opposite and then it gets itself fixed later on somehow.
Pull battery to reset camera, remove it ( remove device in settings )  then bring it back as if new ( sync )
Arm the cameras using ARMED in mode and go to the live view screen, the motion icon ( running man on web, ball and lines on apps ) for the camera should be black ( not gray )... test
If all still NG, go here https://www.arlo.com/en-us/support/contact.aspx
  • 4705 Views
