  • 9 Replies
  • 2174 Views
Nwaterpolo
Arlo keeps flashing, I've removed battery, reset with the sync button. Followed all the guides. It still just starts flashing for about a minute, goes dark, then does it again.
9 REPLIES 9
Streak2
Master Master
Alternating blue/amber usually means a software update is in progress or the camera is resetting.
https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-camera-mean
Remove the camera using the app.
If you press the sync button does it start flashing blue? If so then press the sync button on the base and see if the camera connects indicated by a fast flashing blue after a short while.
Nwaterpolo
It does not start flashing blue, if I hold down sync, it keeps flashing blue and amber and then after a while all the lights turn off, then they turn on again flashing blue and amber
ShayneS
Does the same occur when plugged in with the power cable?
Nwaterpolo
Yes, with or without being plugged in
ShayneS
Have you tried to perform a factory reset with it attached to power and battery separately?
https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
Tommygunn01
I have the same issue.
Flashing amber and blue light.
Where to?
ShayneS
@Tommygunn01 Have you tried to perform a factory reset with it attached to power and battery separately?
Tommygunn01
Hi, yes, I have factory reset.
ShayneS
@Tommygunn01
This LED pattern is supposed to indicate a firmware update in progress. Does the camera come online after a while? How long does the LED pattern last?
  • 9 Replies
  • 2175 Views
