Hi @Bramby
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Hi @mvillan77
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Have you tried to remove the camera from Settings > My Devices > Re-add it and test again?
I have 3 Pro 2 and 1 Pro 4 none of them work correctly on audio. Never have and they cant fix it. It either says audio detected even when set at lowest point. So continues to give notifications .Worthless audio. Camera is good but audio is terrible.
