Have Arlo pro 2. Deleted from account. Now cannot reconnect it to hub. Need help
If you tried on the app, then perhaps try using a PC (browsing to my.arlo.com).
For the Pro 2 and older you don't need to use the app or browser. Simply press the base sync button and then the camera button. You may want to reinsert the camera battery to reset the camera, too.
