  • 935 Views
Ve333
After trying various solutions in the last 1 year I think The only solution to this is throw Arlo camera in the bin and go for Eufy which is much more reasonable in price and does a better job than Arlo. It has reset feature in the app itself and if the camera is stuck you don’t have to personally go and remove it plug back to bring it back online. + amazing battery life.
https://youtu.be/1m8jmwH-5-w
ShayneS
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any methods you have previously performed.
Ve333
Tried the below:
Resetting the devices, removed the battery and put it back after few seconds, switched off router and turned back on - The result: The camera comes back online  but after few days the cameras again goes offline. It is frustating when you are away from home and this happens because no one is available to reset at home. There is no option in the app to reset it online.
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
  • 936 Views
