This is the 4th time I’ve had to buy new Arlo outside cameras. Never fails once the 4mth hits they stop charging. These have before biggest waste of money.
Letting the battery totally die is a likely scenario - proactively charging them works much better. Use this procedure to see if you can get them charging - the key is to plug in and unplug many times until the battery has enough charge to then charge normally.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Would like to buy new camera
@hiesha22 can I help you with your question regarding a new camera?
