Three Pro and five Pro 2. Basestation is "offline" with amber light flashing. My internet connection is perfect. I can even watch my cameras LIVE through a browser but when I try to access the base station settings the whole operation shuts down and says it's offline. Cameras have not been recording motion.
It's been like this for nearly two days. I tried the trouble shooting tips all the way through, short of a hard reset because frankly I'll return it before i re-sync all my cameras.
WHAT amber light is flashing?
The light on the right is amber
Adam85282,
When using more than 5 cameras there are a couple things to note. You would need a subscription plan to support beyond 5 cameras (Premier or Elite) and the base station will support simultaneous streaming of a maximum of 5 cameras.
