Arlo VMA1000-10000S plastic nuts cracked
Arlo VMA1000-10000S
any one else that have problem with "plastic nut"
then I mounted my Pro 2 it cracked
Sven Åke
5 REPLIES 5
your the first to my knowledge...
but in meanwhile, a simple 1/4-20 nut can replace it.
I am in Sweden and we have meteric 6mm
so no that it's not that easy
Sven Åke
You don't really need the nut in many cases. I just screw the camera on until it bottoms out snugly.
I will see first what Swedish seller says first
after that I will test without nuts
Sven Åke
Swedish seller was sending new without questions!
Sven Åke
