My camera was not taken back to charge. Now, it does it charge any more. I took any camera back to charge. It said the charging faults and asked me to unplug and plug again. Issue continues existing. I suspect the charging cable has problem. Ideas?
Message 1 of 4
1,739
It is resolved by using its original charger.
Message 4 of 4
1,624
You can try another charger that supports both 5v and 9v outputs such as those used by many newer phones. That should prove whether it's the charger. Hardware problems can be resolved by using your warranty and using the Contact Support link at the bottom here.
Message 2 of 4
1,715
Maybe also try the charger with a different outlet.
Message 3 of 4
1,678
Message 4 of 4
1,625
