Arlo Solar Panel not working; Adapter version 1 vs Adapter version 2
  • 1 Reply
  • 1712 Views
banking
I think the problem is not the Arlo Solar Panel itself but is the adapter version 2 that is connected to Camera (the male) part. We own 5 Arlo solar panels with the Adapter version 1 and they all work fine. We just bought another solar panel and we notice that the male end of the Arlo Solar Panel  Adapter version 2 connection is different, it has the double round rubber that sticks out and this is making it more difficult to plug the male end of the adapter version 2 into the Arlo Pro Camera. I cannot understand why they change this. If you have a product that works fine and sometimes when change it to get creative, you make things worst. Watch the video and see for yourself, I do not know if your Arlo Solar Panel with the Adapter version 2 is working or not, but mines is not.
I need to the Adapter version 1 that goes to the original Arlo Solar Panel. I need to ship the Adapter version 2 back to Arlo Net Gear and I need the original Arlo Solar Panel Adapter version 1. This could be many of you are having problems
https://www.youtube.com/watch?v=OU62AkxnmpU&feature=youtu.be
****Watch the video I uploaded, this will explain it better.*****
The reason for change is the older model is some cases was allowing water intrusion.... the two rings are sort of o-ring sealers.
They are more of a pin to get in place, but should be better as to keeping water out.
You need to contach Arlo support if you can't get this to work for you.
  • 1 Reply
  • 1713 Views
