If the camera STOPS seeing motion it will stop ... then there is the reset time of about 15+ seconds...
If it doesn't see motion , it doesn't record.
I recommend NOT using "till motion stops " but a fixed time... never liked the way it stopped.
Thanks for the prompt reply TomMac, however what it sounds like is there is a bug in the system and based on past posts, has been there since at least 2016. I would have thought Arlo would address this. The troubles with using a fixed time are, limited to 120 secs compared to 300 secs on dynamic mode and, all videos will be at that fixed time and take up too much data. I am on a limited data plan on satellite internet so need to be frugal with usage. On dynamic mode I usually get small videos if there is not much activity, but I want to have as much as possible when there is activity that lasts longer and may be significant.
I’m also having this issue. Recordings are usually about 20 seconds long, even though motion has continued for much longer. For some reason, the recordings are longer when, “Arlo Smart” detects a package.
