Arlo Pro2 not connecting back to Base Station VMB4000
  • 47 Replies
  • 8182 Views
  • 14 In Conversation
Ken_Wong
Started off with a need to pull off both Arlo Pro2 camera from their set location for charging. After charging, the Arlo app wasn't able to connect to the Pro2 camera. On checking the Base station, it wasn't able to connect either.
Did a host of troubleshooting including the internet port cable, nothing works. So I did a hard reset for the Base Station. It is now working with 3 green lights and the Arlo app can detect the Base Station.
However, I have another problem now. In doing the hard reset, all the existing camera were removed, and needs to be reconnected. The problem is now they cannot be detected during setup - after synch both the base station and camera, where the base station has flashing yellow lights (for the camera) and the cameras had flashing blue lights.
To mitigate possible low power issues, I had test synch a camera that is still charging with cable as well. Same blue lights, but no detection. I did also notice that the Arlo phone app seem to be different - seems to also had a version update that was done automatically.
What could be the issue here ? Any suggests from Arlo experts?
47 REPLIES 47
@fisian wrote:
Unfortunately I only have these 2 cameras with their base and the one router the base is connected to.
@BrookeN  is asking if you can do the install from another device.  For instance
  • a PC (browse to my.arlo.com)
  • a tablet with the app installed (logging into the same account)
  • another phone with the app installed (again, logging into the same account)
fisian
I have tried accessing the web interface, but it keeps asking me for a subscription and does not allow me to proceed without it. I assumed that a 7 day cloud retention should continue to remain free for Arlo Pro 2? Or is there another way to log in online?
BrookeN
You should be able to log into My.Arlo.com without a subscription. Can you send me a screenshot of what you are seeing when trying to log in.
If you are using your phone or a tablet to access the web interface, then use a PC instead.
fisian
Thanks, I have managed to access the online dashboard in a browser now on a different computer. On Android / mobile, I still cannot get past the subscription options.
Anyway, in the dashboard I can see the base station just like in the android app. I have tried adding a camera in the following way:
- clicking a plus sign in top right
- clicking on "others"
- clicking on "Arlo"
- following the instructions on the screen (pressing a sync button on the base until it starts flashing, pressing a button on the camera, waiting for faster flashing)
In the end, the result is exactly the same - the lights on the base station and the camera both first flash slowly (blue), and then - SIMULTANEOUSLY - start flashing fast (so they see each other), but then the light on the base station stops flashing, the light on the camera turns off and there is no camera added in the dashboard.
Do you have any ideas on what else to try?
Thanks!
fisian
a kind reminder of the message above.
Thank you very much.
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
BrookeN
@fisian thank you for providing that information, support will be reaching out to you as soon as possible.
fisian
Thank you. It would be great if they could reach out to me today, anytime within the next 12 hours as I will be leaving and would like the system to work. Would you please relay this to the support team?
Mushy1976
I have exactly the same problem. One camera stopped working a while ago so I tried to add it to the system again after taking out the battery for a minute then ran through the process again on my laptop and wouldn't connect or be visible again lights looked like they had connected but alas no it was just seeming like it as the lights changed from blue slow flash to fast on the camera then stopped.  Both cameras now won't work.
BrookeN
Can you try to add them to the account by using a different device by chance?
Mushy1976
Yes i did try numerous times on my phone too
BrookeN
BrookeN
Thank you for providing that information. I have reached out to support they will be reaching out to you as soon as possible.
HitchN
I have been having issues re adding the Arlo Pro2 cameras to the Base station, vmb4000.  I could not do via the iphone app or the manual sync on base station button/camera button.  I managed to get two of the three camera ‘claimed’ by the base station, but I cannot get it to find the third camera again.  Oddly when i was adding the two last camera, two serial numbers showed up, but I could only add one.  The second camera that showed up was the camera that i was adding now.  So I know that the base station can see it, but I cannot get the camera to appear again on the my.arlo.com Looking For Device page.
any idea what to do?
@BrookeN can you help?
lapietra
Hello, so far nobody contacted me.
With a VMB5000 it worked like a breeze.
With another VMB4000 I had the same problem.
Is there a way to update the old firmware on both old VMB4000 ?
BrookeN
@lapietra thank you for providing that information, I have reached out to support. They will contact you as soon as possible.
Myoungjr85
I reached out about this same issue a few months ago and was told my software was outdated and I could just purchase new equipment. In total I have 5 cameras and 3 have been off my network for months. I have tried adding them through the pc as well as the app but no luck
@BrookeN Can I have someone reach and assist me with this trouble?
lapietra
I have 7 cameras, and finally the solution has been to replace the VMB4000 by a VMB5000 and everything now works like a breeze...
ollie2308
@HitchN
did you have get this resolved... I'm having the same issue when attempting to sync my 4 pro2 cameras...  I can duplicate the behavior of seeing 2 S/Ns and then failing to sync the last camera
EA74
I am having the same problem, but it started with this last firmware update. After the firmware update it put me on another trial period of one of their plans. The plan expired on monday and now I have a very hard time connecting to a camera.
Define "have a very hard time connecting to a camera". There was a problem yesterday when trying to use live view but that's been fixed.
savage51
After working on this virtually non-stop, I have something to offer that I hope works for you all like it did for me.
I tried everything listed in this thread and a couple others.  EVERYTHING.
Nonethless, I kept at it because I knew that the camera was communicating with the hub.
I realized that it had to be a software issue and that perhaps a different camera under the add a device section would work.  This whole time I was using Arlo under OTHERS.  That is when I saw it, plain as day - PRO SERIES and under that PRO 2.  BINGO it worked!!!!
GO GO GO GO - I truly hope it also works for you!  Furthermore, I just purchased the Ultra2 and FYI they were inferior to the Pro2 cameras in almost every respect.
Thanks, Savage51
  • 47 Replies
  • 8183 Views
