  • 1 Reply
  • 961 Views
Ashutosh
I misplaced the charging cable of Arlo Pro 2 camera. It was disconnected from the solar panel also so now  I need to charge it as it was having less than 10% charge. I am using another USB cable to charge and it shows that it is charging. But even after few hours it is not charged. From where i can buy the charging cable of Arlo Pro 2 camera?
The cable itself is not special as long as it fits well into the camera. The charger just needs to be one that supplies 5v at 2A, which you can determine by looking at the label. You might want to reinsert the battery to see if that resets the percentage display. Also, try the app as well as the web client (the latter has issues with proper display but might still be worth a try).
  • 1 Reply
  • 961 Views
