  • 1481 Views
nedwards9820
Would the Arlo Pro2 work as a nest box camera for a bird nesting box?  I can't find the minimum focus distance stated anywhere.
slompochomp
Luminary
Luminary
I am not sure, you could try. I know my Arlo records spiders that happen to crawl around the camera.
Spider
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
Manually test it. Go to view view and move closer and closer until no longer acceptable.
I would use a distance of more than 12 inches... here you govlcsnap-2018-12-01-16h19m17s928 (2).png
  • 1482 Views
