Arlo Pro2 as nest box camera
Would the Arlo Pro2 work as a nest box camera for a bird nesting box? I can't find the minimum focus distance stated anywhere.
I am not sure, you could try. I know my Arlo records spiders that happen to crawl around the camera.
Spider
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
Manually test it. Go to view view and move closer and closer until no longer acceptable.
I would use a distance of more than 12 inches... here you go
