Arlo Pro showing red on image/video
Dear all, pictures and videos only be shown in red. Does anybody face same issues? Thanks for supporting, best regards
Generally that means the IR Filter used for Nightvision is stuck.
You can try sliding a strong magnet along the bottom of the camera (under the lens) and see if that unsticks it. For instance, one of the magnetic mounts.
Thx Stephen for fast reply and feedback. I will try… hopefully it will work. Best regsrds
