Arlo Pro base station dead in 3 days
  • 4 Replies
  • 1926 Views
Dionlund
Hello
My Arlo Base has been offline the last couple of days...
When I looked into the problem - my Arlo Base is "dead", it seems like there is no power on.
I have tried to change to another wallplug but the base is still completely "dead" - no LED is on.
What could be the problem ?
Is it possible to buy another Arlo Base, and connect my "old" 5 Cameras to this new Arlo Base ?
Best Regards
Dion Lund
@Dionlund wrote:
I wonder if it is possible to use the "old" cameras on a new Arlo Base ?
Yes, you can use old cameras on a newer base.... the only camera that doesn't work is the Ultra, which requires the Ultra base. ( but even the Ultra base can use older cameras )
Dannybear
You haven’t bumped the on-off switch next to the power plug - socket on the base station?
Alternatively have you checked the power adapter is working that powers the base?
Dionlund
Hi
Thanks for your reply.
I have tried to reset the base, unplug for 5 minutes and retry .. no luck.
The on/off button I have togglet for several times - no result.
best
Dion
Dionlund
Hi
Thanks for your reply,
I will order a new Arlo Base station, and hope this solves my issue 🙂
best
Dion
  • 4 Replies
  • 1927 Views
