Arlo Pro Records 5 Minutes When Set To when motion stops
Arlo Pro 2 is set for Record when motion stops, but only records for approx. 11 secs. How do I correct this?
If the motion that triggered the camera to record is not seen by the camera, it stops....
11-15 sec is about the norm.
You can always edit you mode to use a fixed time up to 2 mins... usu 45-60 secs is plenty
