  • 2 Replies
  • 700 Views
Glasto
Luminary
Luminary
Hi everyone.
Getting a white type pixelation which dances across the top of live view and recordings. Also a vertical type thread which runs top to bottom. Is the camera on it's way out? Done really well if it is. Thanks.
Glasto
Luminary
Luminary
Removing the battery and reinserting didn't solve it.
But, removing the camera and re-adding it did. Pixelation gone. Thanks for your help.
It could be a camera hardware failure.  Have you tried removing/reinserting the battery?
If that fails, I guess you could also try removing the camera from the account and then re-adding it.  Though there is some risk doing that - several have run into problems re-adding legacy cameras to their account.
Glasto
Luminary
Luminary
  • 2 Replies
  • 701 Views
