Arlo Pro 2 shadow false detection still occur when plugged in?
I have Arlo Pro 2 cameras that are starting to get a lot of false motion detections from shadows/light during peak daylight hours. Would this issue go away if I purchased an outdoor power adapter and plugged my cameras in? Or could the issue be controlled with activity zones when my Arlo Pro 2 is plugged in?
The false triggers that happen won't change if powered....
Placement and angle would prob help more along with sense level adjustment.
Powered with activity zones could help if the zones eliminate the shadows/light areas from the active trigger areas
