I completely started from scratch by creating a new account while using google chrome and using a gmail user name. When I started from scratch I did nothing on the app and went with 100% set up on a PC. I can’t begin to guess if it was a compatibility issue with an I phone, using the app for initial set up or it being very picky with what browser you use but I had success following the above process for what it is worth
Sorry, I can't help you. Given my experience over the past couple of years, you will be so much happier and better off sending that Arlo system back to Amazon for a refund, then buy a different brand. Arlo has told of problems, no capable customer support (which you have experienced), and every update, they break something else, and it stays broken for months. Save yourself the headache!
@DarrylW wrote:
I am on my second Arlo Pro 2 Three camera system
This is with the Arlo Pro2 cameras (not the newer Pro3s)?
Have you tried accessing the cameras with the web client ( https://my.arlo.com )?
If you get the same error there, can you post a screenshot?
@DarrylW wrote:
Cannot even get to the cameras on the web client ( opened in safari and chrome)
What do you see when you log into https://my.arlo.com ?
Are any devices shown (including the base station)?
@DarrylW wrote:
This pops up when I log in. If I then go to the menu and select the cameras it says that the page is invalid. I have also tried to access it in chrome and it will not do anything
Can you try this on a PC?
