Arlo Pro 2 problem with re connecting to iPhone 6s
I removed my base station as it wouldn’t show as connected to the internet although it was. I’m trying to add my base station Arlo Pro 2 back again onto my iphone but it just keeps saying no Arlo device found. I’m using the same network can anyone advise me please
How did you remove it? From Settings, My Devices? If so, remove ALL devices seen there. Hold the reset button until the LEDs flash amber. Use the Add Device selection on the Devices tab to claim the base. Sync the cameras. Update firmware as you go if prompted.
