Arlo Pro 2 power cables
HI All
Is it possible to wire the power cable for the pro 2 to a house lighting ring main, i cannot see a real reason why not as it is only a usb cable and does not use to much power. ?
Many thanks
You mean for a light socket? If so maybe something like these will help. Keep in mind you will still need to use the USB power adapter.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
Not sure what you're talking about with a "house lightin ring main" but I assume you mean AC power like for lights. The cameras work of 5 volts DC which the house works off 120 voltas AC. Connectin the camera directly to the house power would be... interesting (think melting ,fireworks, maybe fire).
A 5v-only adapter should run the camera as liong as it can supply at least 1.5A. That won't charge the battery, though, which requires 9v.
Im in the UK, We have a power circuit and usualy 2 seperate light circuits, all of which run on 240v but the lights are fused with a 5 amp fuse and usualy a 6 amp trip in the consumer unit. So i am thinking can i wire in one of those plug sockets with a USB plug on it (Feels safer than an adapter plug, also Arlo had recalled the adapters in the UK, not sure if that is sorted now or not) and just then plug in a USB cable to charge the camera? Not sure what voltage that would produce, but a couple of guys on here have quoted that the camera needs 5 - 9 volts?
Use of any adapter that supplies 5v at 1.5-2 amps should be fine. Check the device you're thinking of using for specs. The 9v part is needed to charge the battery but not to run the camera.
