Not long had the pack of 3 arlo pro 2 and the battery is nearing charge time. Busy house so they lasted approx 1 month from an 80% charge (approx 15% left)
I'm trying to run the power cables to all three as they are reasonably close together, but is there a way to use 1 mains plug or do I need to use 3 (one plug for each camera)?
You really need 3 unless you have access to a totally different power supply that can support the extra current.
As long as each socket can provide 1.5-2 amps @5V, you should be fine. The catch is that many multiple outlet devices only have a total current rating, not an individual one. Maybe if it can provide 5 amps or so in total it would be ok.
https://www.amazon.co.uk/Worldwide-Adapter-GOSCIEN-Charger-Universal/dp/B077JN8S7K?ref_=fsclp_pl_dp_...
That shows the potential issue - two at 2.1A and two at 1A. It's possible that the cameras might work on 1A but it would be better to find one that supports 2A on all ports. There's no technical reason that I know of that would make this impossible - it's just a power supply and how they divvy it up is just a design decision.
You’ve been a great help. May pop into shop tomorrow and see what I can find. Will keep ya posted and thx very much for your time.
