Arlo Pro 2 not recording
  • 8 Replies
  • 2791 Views
Road12
It seems over the last couple of months my Arlo pro 2's will randomly stop recording. Nothing on my end has changed with regards to connections or locations of the cameras and hub. They have worked great for years, but it seems since Arlo released info on End Of Service months back, they have randomly stopped recording at various times causing me to miss events. I have to reset the Hub which will get the cameras working again, but it's short lived, and within a few days they are right back to not recording and missing events. I've read others having this same issue. I wonder if Arlo is causing the issue trying to force people to their newer product lines.
8 REPLIES 8
Road12,
Are you using a schedule or any third-party integrations? When you notice they are no longer recording, are he cameras still "Armed"?
Vargid
I'm having the same issues with one of my cameras. I've removed and readded the camera and it won't record any clips. Resetting the base station doesn't do anything. I also lost the ability to view my doorbell and can't read it either as it can't find the device.
Vargid,
What model camera is the the camera you're experiencing an issue recording with?
Vargid
Camera is an Arlo Pro2 camera which is plugged in w/ power via USB running fw 1.125.17.1_11_de8490d, Hardware (H3).  It is the only camera i have plugged in with this issue and used to be very consistent with recording.  I can view live video on demand through the app fine and responds to motion, just not recording clips on motion.
Vargid,
If you manually record within a live stream, does the recording arrive in the library? Have you checked the active mode to make sure the camera has rules telling it to trigger a recording on motion?
Vargid
Yes, manual recordings show up in the library for this problematic camera and all cameras are "armed" to record on motion.
Maybe try the motion detection test next.  It's documented here:
Vargid
I've done the motion detection testing and it picks up motion.
  • 8 Replies
  • 2792 Views
