Arlo Pro 2 mount rusted. 2 of them are bad so can't unscrew camera anymore.
Hi
I have 4 arlo pro 2 mounted with Arlo Mounts about 3 years. All 4 mounts are rusted. 2 of them are so bad that I can't unscrew the cameras anymore.
I tried applying WD-40 without success.
Sounds like you may have to remove the mounts from their location...GENTLY apply a bit more force with a set of pliers when on a work bench.
Then take pics and try Arlo support.
Remember any mount with the factory standard 1/4-20 thread will work.
