- 2
I'm frustrated with Netgear in that I feel they want to not only sell you an expensive camera system but then decide to remove features so that you have to contribute to a monthly fee service. Zones were the main reason for purchasing Arlo... what will be next... charging your customers to see their videos... As a customer I'm concerned that Netgear is more concerned about finding ways to charge customers for Zone services which should be part of the software. Give Zones back to your customers for Free!!
@RickDizzle wrote:
Shayne,
Are you saying if we just use the battery we should be able to use motion zones? If so ill reboot all my system and see.
You can if the camera is on the smart subscription.
Note that when you just use the battery then the recording is still streamed to the cloud every time motion is detected (whether it is in the zone or not). The cloud then figures out if the motion was in the zone - and only stores recordings when it was. The others are dropped.
So while this is an effective way to control the number of recordings and notifications, it will not improve your battery life.
- 2
