  • 2 Replies
  • 1511 Views
slapjack
Bought this system from my friend. Everything is up and working but I can't find an option to add the system to HomeKit anywhere. Followed all the support articles (the directions don't line up with how the Arlo Secure app is laid out now) and all I can see is an option to add to Alexa.
How do I add this to my Apple Home?
Thanks in advance!
HenGijVer
I have the same issue
I really cannot find the option Homekit in my Arlo Secure app....
BrookeN
Follow these steps:
To setup an Arlo device without a setup code:
  1. Launch the Arlo Secure App on your Apple device.
  2. Tap Settings > My Devices.
  3. Select an Arlo SmartHub or Arlo Base Station.
  4. Tap HomeKit.
  5. Select the Arlo SmartHub or Arlo Base Station you want to add to Apple Home.
    If you receive an Uncertified Accessory Error message, visit: When adding my Arlo Base Station to Apple Home, what should I do if I receive an Uncertified Accesso...
  6. Select a Home or tap Add New Home.
    If you don’t have a Home set up in the Arlo Secure App, you are directed to create a Home.
  7. Select a Room or tap Add a New Room.
    If you don’t have a Room set up in the Arlo Secure App, you are directed to create a Room.
  8. Tap Continue to add devices to HomeKit to add devices or additional Base Stations.
  9. Continue through the setup flows to confirm the name and room placement for each device.
    Note: The name that you give each device is used for Siri commands. Choose a unique name that is easy to remember and pronounce.
  10. Confirm the name of the device.
  11. Tap Skip, or rename any other devices as needed.
  12. Tap Finish.
    Your devices are ready to use with Apple Home.
  • 2 Replies
  • 1511 Views
