  • 1007 Views
JBT96
I have base VMB4000r3 using firmware 1.12.2.4_2772.  My Pro2 cameras are H3, firmware 1.125.13.0_31717.  Two cameras were connected for several months with no issues.  Both were at least 10 feet from the base station.   Tried adding a third camera in early June.  Now when camera is moved more than 6 inches from the base, it goes offline.  Otherwise, it functions properly.   Also, very slow to load a live view when using the app.  Internet provider is Comcast.  I have re-set the router, re-set the base, power cycled the base, removed camera batteries, resyned, removed and reinstalled base and all cameras.  Nothing works.  Thanks for any suggestions to solve this isse.
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
JBT96
I looked through all of the provided troubleshooting documents and did not find a solution to my problem. Base firmware has since updated, but issue still exists. Camera signal strength is lost when moved more than a few inches from the base.
ShayneS
@JBT96
Did you try the support link I provided?
  • 1008 Views
