Arlo Pro 2 - display video feed to my Television screen?
I have had Arlo Pro2 cameras for about 2 years. They are glitchy but after much fiddling, I have settled on a moderate level of satisfaction.
I have "Hard wired" power to all of my cameras (4). Thus, I don't have issues with battery life.
I have also installed IR (850nm wavelength) spotlights on a couple of them to improve my night resolution.
WHAT I WANT TO DO is to display my camera feed to my television set. I just want the same or similar display as what I have on my Iphone or Ipad device.
No matter what I read or search on the Arlo site, I can't find anything that indicates the Arlo system is capable of this simple and intuitive way to display the camera feed?
I have C-Spire high speed fiber for my television and Internet. Shouldn't it be possible for my home router to send the feed to my TV? The TV already uses a router system for displaying the signal it receives from C-spire.
Thanks!!
The cam will not directly stream to the tv... but can be done via third party prgms.
I use Alexa and a fire stick ( gen 2 needed or newer ) and it works well for live viewing.
You need to set up the alexa service first.
Be careful to name the cams separate names ( cam1, cam2 doesn't work well )
