Summary: Arlo Pro 2 cameras connected to VMB4000 base station - Camera sensitivity setting keeps reverting from 0% to 80%
I get a lot of wildlife around my property continually setting off the cameras. I frequently reset the Arlo Pro 2 camera sensitivity setting to LOW yet consistently when I check - maybe a few days later - the sensitivity setting for each camera is back up to around 80% - thereby draining the batteries and capturing footage that's pointless !
Any ideas anyone how I can set to LOW and ensure it stays there ? even after camera/base station resets ?
Which app UI do you have?
motion trigger sensitivity is adjusted in the camera rules not the motion test function.
Ah ok.
Found ‘rules’ and modified settings. Lets see what happens.
Thanks for your response !
