Arlo Pro 2 camera not charging
  • 5 Replies
  • 1728 Views
Deano89
Hi guys
Wondering if anyone has any suggestions.  I have 3x Arlo Pro 2 cameras all with the same setup, genuine Arlo Outdoor Power Adapters connected to the same base station.
One of the cameras has started refusing to charge.  It is never been moved so plugs etc have not been damaged.  I have tried both the charger and the battery from one of the other cameras which I know are working and no luck.  I have also tried the battery from the faulty one in another camera and it is fine so appears to be the camera itself with the problem.
The faulty camera is 1 year and 1 month old so just outside the warranty but Arlo support seems really difficult to get a hold of in these situations.  I'm just using the included free subscription too with the 7 day rolling storage so don't want to upgrade my account.
5 REPLIES 5
there are several things to try...
first read this;
https://www.arlo.com/en_dk/support/faq/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I...
By using a pencil eraser, gently wipe the battery terminals and the terminals in the camera to make sure there is no corrosion on them.
Try the camera WITHOUT the battery as the power supplies should function the camera after removed.
Last, it to check both the power supplies and usb terminals/port to verify all looks ok ( as best as you can )
Deano89
Unfortunately no luck. The camera sees the battery just fine (it still has half a charge) but will not charge. There is also no corrosion on the camera or battery terminals. As mentioned I have also tried multiple genuine Arlo power cables but no luck. The camera also does not light up when the cord is plugged in if the battery is not plugged in.
There's a small ribbon cable between the USB port and the main camera body that would be used to charge the battery. A few folks have somehow damaged that cable so charging no longer works. There are no parts for sale so you'd need to charge the battery in another camera or buy the external charging station (I'd also buy an extra battery).
If the camera is running on battery ok (just not charging), then you could just get an external charger and continue to use it.  Awkward, but it avoids trying to get a new Pro 2 camera.
Deano89
Oddly enough my second of 3 cameras has just started doing exactly the same thing. No registering that it is plugged in. Pulling the batteries out every time kind of defies the point as the cameras aren’t easily accessible and I’ve specifically run the cords for the Arlo chargers so they are always plugged in so I can “set and forget”. Bit disappointing that 1 month out of warranty two of the 3 cameras are unusable.
  • 5 Replies
  • 1729 Views
