When I insert a battery in either side of the charging station there is no amber or green light displayed. When I insert a different battery, I get amber indicator light on both sides. Does this indicate that the first battery is totally dead?
Maybe... try and insert same a few times to see if it comes back. It may have been drained to low to start charge.
It need a min charge in the battery to properly start.
like this;
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
like this;
TomMac,
Thanks for the suggestion. Plugging in the camera and loading the fully discharged battery and waiting for a long period of time worked! It just took a long time.
Thanks,
DonCar
Good to hear...
try not to allow the battery to go below 10%....usu I get an alert at about 12-14% left.
