My Arlo Pro 2 camera batteries have starting draining within a day or two. Nothing has changed in terms of location or sensitivity. What is causing them to drain so quickly? I have 5 cameras total and they are all experiencing this issue.
What have you tried? Mine are running fine with no abnormal drain. A quick reboot of the base would be a good start.
Problem resolved after a restart of the base station. Anyone know what in the base station would have caused the batteries to drain?
The usual problem is a poor connection between the base and camera. Why a reboot of the base would fix that is unclear.
