Can anybody help.....
I can get my Arlo Pro 2 to work however the moment i plug the base station into my router it seems to automatically block my BT Wholehome discs from working and therefore evrything else in the house loses internet connection
Ive seen recomentdatsion to try and keep the 2 at least 15m apart but this isnt very practical.
You can run up to 100m on etherent cable or use a wifi extender with an ethernet port ( that links to you home wifi )
I bought wireless cameras & wireless router for the reason I dont want to run a 100m ethernet cable - i want my router, my Arlo hub & my BT wholehome disc (wifi mesh) in a single location.
There must be a simple fix surely
I run 2 bases , each 4 ft on each side of my Orbi router.... must have something to do with the one your using... can't give you an answer except move it away
