Arlo Pro 2 cameras electric plug in sync
I have an Arlo Pro 2 security system with two cameras. I originally set them up with the battery packs and synced them to my wifi network. I subsequently changed to electric plug in and it works fine. I now put in a new Mesh network. Do I need to sync the cameras again? All three lights are solid green on the base station. If I do need to sync them I assume I'd need to do so with the batteries reinseted. Thanks for any help.
when the base or power goes out for a short time ( or battery change ) the cameras should auto-resync.
Since all the leds on the base are green, you should be good... but you can also check them on the live view screen.
