Arlo Pro 2 base keeps losing internet connection after updating firmware to 1.14.0.2_2776
After upgrading the firmware to 1.14.0.2_2776, the base keeps losing internet connection suddenly within a day. It makes me losing my real-time monitoring and video feed also.
It is very annoying and I am very regretful buying these expensive useless systems.
How to solve the problem? Can your engineers test the firmware thoroughly before releasing it?
Same issue here
Hi drdoom and Hoity-Toity,
Have you tried to power cycle your Base Station to see if that helps?
Yes, I have tried rebooting the base by switching off and then on, but it kept losing internet connection or camera connection several times a day suddenly.
I would suggest contacting the Support Team to further investigate this issue. You'll find several options for contacting support in the provided link.
