Is there a wall mount for Arlo Pro 2 security camera whereby i can keep the wire plugged into the camera and also attach it to a wall mount?
I purchased a wall mount but there is not way for the camera to be attached to the wallmount and have the usb cable plugged in. If i want to attach it to the wall mount, i would have to use it wire-free.
Would appreciate it if someone knew if there is a wall mount?
Please have a look at the attached picture for a better understanding of what im looking for.
The Outdoor Power Adapter for Pro, Pro 2 and Go (VMA4900) should have come with a Wind Bracket and an Extension Bolt that you could have used.I am not sure what elce you need because in your picture I see the camera is connected via the micro usb and attached to the wall mount without issue.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
sorry I was editing my post above.
Is there another wall mount that you had purchised ? and if so which one ?
By the way I use the Outdoor Security Mount in White (VMA1000) and from your picture it looks like your using the same thing.
So when i screw this mount into the camera, the usb cable doesn't plug in. Im looking for a mount which doesnt have that circular disk around it.
ok Ya I would suggest getting the official Arlo products, I have read bad reviews on 3rd party accessories.
Get what I got and you should be set.
Ya I just looked up what you got, I am sorry....waste of money.
remember the Outdoor Power Adapter for Pro, Pro 2 and Go (VMA4900) also comes with a Wind Bracket and an Extension Bolt that helps extend the camera so that the micro usb works well with the mount and you can fully move the camera around.
Yup.... Those 3rd party mounts have issues with rotation and poor quality, and the 3rd party power adapters have issues also. No issues with the official Arlo accessories and they are powered up 24/7.
you aslo get 3 second look back and the option to create dead zones on the arlo app when they are connected to the micro usb ac power.
you could even pull the batteries out and the camera will still function when it is connectioed via the micro usb ac power.
