  • 4 Replies
  • 2849 Views
poy
How does the Arlo Pro 2 compare to the Arlo Q?
Plugged in, they're similar except the Q isn't weatherproof.
poy
Mine's waterproof (Covered the speaker and mic with silicone)
No difference in quality as far as video recording goes?
DvxAznxvb
If you covered with silicon doesn't that render most sounds dull? There are many fine meshes you can attach that don't impede input and output of sounds
poy
Yes but I only need it for video in this location.
  • 4 Replies
  • 2850 Views
