Would be great to include in the Mode "edit" or in a Custom mode the rule and the option to completely turn Off certain cameras as in the "Device Settings" of each individual cameras. Seems like an important missing option. For example when home I do not want All Cameras to be "On" even if record is switched off. I would like to only keep the outdoors Cameras "On" and have the certitude of privacy in my home.
You need to create custom modes and then split the cameras up into groups ; inside / outside....
Any camera NOT in the active mode is OFF
Not quite as they can still be monitored even if not on Record. Camera are still active unless you go to each individual "Device Settings" and turn the Camera "Off". You will no longer be able to access the Camera or monitor them at all until you Turn it "On" again in each Device Setting. This should be included the Mode fonction.
