Arlo Pro 2 Sensitivity Settings
Hi,
The short- what sensitvity setting do you use?
Recently setup Arlo Pro 2 - 2 camera setup. Camera was triggering all motion for wind and anything else. Found and turned the setting down to 10. All I want to pickup is people. Just curious what you guys use or recommend.
The motion detection test is just that - a test. It gives you a number to plug into your modes and rules. Read the FAQs here on how to determine and set the motion sensitivity for each camera in your rules. Consider custom modes so you have full control.
