Arlo Pro 2 Scheduling options
  • 1 Reply
  • 1207 Views
PeterHarskamp
Hi All,
I have a weird (or not) problem. When having multiple camera´s i want to make several schedules. I dont want my indoor camera´s to activate all the time on motion. But my outdoors should.
Now i know acording to the instruction video you should be able to select your camera where you want to add an arming schedule for  if you create a new mode. but when i do that, i just creata mode that it will start recording, how do i connect that to a time schedule (and then a always on for the outdoor) ?
Regards
Peter
You have to create custom modes and then bring them into the schedule to run for the time frame wanted.
remember to split the cameras into the goups needed.
"I dont want my indoor camera´s to activate all the time on motion. But my outdoors should."
So, if you have 3 cameras a&b inside, c outside... create two new modes for a & b, then c.
schedule C camera mode on when a&b are off, when you need all on , schedule Armed mode... if just inside then the a & b mode.
tips;
Only one schedule can run at a time
Any camera NOT in the active mode is off
Running a mode thru midnight must be split... up to 1159pm and next day 12 midnight on
  • 1 Reply
  • 1207 Views
