How do I turn off the siren remotely, using the app?
If you turned it on by using the app, you can turn it of, too. If it turned on because of a rule or if someone pushed the button, I don't know that the app can turn it off. You could try using the app to turn the siren on (even though it's already on) and then off to see if that works.
You could use the app to reboot the base which would turn the siren off as a last resort.
Thankyou - turning it on using the app (even though the siren is already on), then off using the app, worked.
It's a solution that's a workaround for now. Arlo, this feature requires a more elegant intuitive solution.
