I have read a lot of forums posts about this, but am still confused.
Say I have the Free Plan.
With the Arlo Pro 2, if I keep it plugged into a power cord, can I do Continous Recording locally to the USB drive on the base station, without a plan?
Since it's only locally, not the cloud.
No, you need a CVR subscription to get continuous recording.
With the power cord plugged in, you get 3 second lookback (3 seconds of video before the motion detection event) and also motion zones.
When you have CVR, it's only CVR to the cloud. Your backup USB drive only records motion event videos
Now what about the Arlo Q Plus, since it has a built in SD card slot, can that one do CVR for free?
No. CVR is an optional subscription. No Arlo camera has the ability to use the SD card for CVR or similar.
Oh wow, so the software blocks the SD Card in the Arlo Q Plus, from being utilized, unless you have a CVR Plan? Interesting
The SD card will make a backup of motion events but won't record continuously
You're reading into things. CVR and motion recordings are two separate things. The SD card will record the same videos as are available in the library. CVR is not recorded locally in any situation and is available only from the server if you have the CVR subscription.
I understand. I'm noting the software blocks you from recording 24/7 locally on the SD card, unless you buy a CVR plan.
Our own SD Card does not use their cloud nor cost Netgear anything. Netgear could unlock that feature and allow us to record 24/7 to our own SD card. No, it would not be to the cloud like a CVR plan, but would still be 24/7 recording locally.
Anyhow, so what about the motion alert recording length. I heard you can increase the length of the recording to a fixed time. Does that apply to the free motion alert plan? We can set how long it continues to record when motion is detected?
Even if you buy a CVR plan, you cannot record continuously to the SD card
If you set a fixed recording time for motion activation, you can choose anywhere from 10-120 seconds. This is irrespective of the subscription plan you're on
There are no limitations placed on the free plan other than the number of days videos are available from the cloud. Edit your modes to change the recording length and any other settings. There are FAQs here to read for full details but quickly use the Mode tab, click on your base and edit your modes (Armed by default). I'd recommend creating your own custom modes for complete control. Be sure to save as you go.
