Arlo Pro 2 - No longer working
  • 5 Replies
  • 1725 Views
snowangel123
We have 4 Arlo Pro 2 cameras and they are offline and saying we need a subscription to use our cameras. It was my understanding that you can still use these cameras without a subscripton.
Could someone please let us know what is going on with these cameras? This just recently happened with in the last2 weeks.
5 REPLIES 5
There's been a couple of other users reporting this.  @JamesC said Arlo was investigation on another thread.
snowangel123
Hopefully we will find out something soon. Stephen Thanks for the information.
snowangel123,
If the cameras are showing offline, that could indicate a different issue. Are you able to provide a screenshot of what you're seeing in the app?
kfrank8506
Actually the message says they are INACTIVE and require a subscription. Happened to me when power cycled in the house and the base station reset.
kfrank8506
Solved for me  (were INACTIVE not offline):
We had the same error message saying our cams were inactive and needed a subscription, after a base station power reset a few weeks ago.  We have ARLO PRO and PRO 2s that should not need a subscription to activate.
We removed the Base Station, and re-added it and all of the CAMS (we have 4 wireless) and voila.. all is good.
Note: after the base station is "re-discovered" and added, you can re-add your cams by simply clicking SYNC on the base station for 2 -seconds until the SYNC light (right) blinks and then bring the cam within 2 feet of the base station and click SYNC on the CAM for 2 seconds. When the blue light stops blinking, it should be added under the base station.
I will add this post to a few threads since I see so many are still having this issue. TECH SUPPORT, feel free to add to or revise these instructions to help those that need this fix.
ARLO has honestly been a great product and I would hate to think about replacing our rather large investment with a lower quality product.  If you can afford the monthly fee and new equipment, I HIGHLY suggest it.
  • 5 Replies
  • 1726 Views
