Arlo Pro 2 Multiple Events Not Recording Correctly
I received a notification of motion detected on a camera - when I first looked it showqed a person enterying the house,door wide open and then finally closed - however the recording only shows the middle "event" with the door wide open
My setting was for record until motion stops which should have given me 2 recordings ie when the person arrived and when they left - I have now set the recording time to fixed 2 mins
Is there a delay before recodring starts after first motion detected, is there a delat between motion events that can cause later events to be missed ???
Cheers
Dave
I've always found a fixed time better... If set for till motion stops, when the camera doesn't see motion anymore it stops and then there is a reset time about 5-10 sec before the cycle restarts
