Arlo Pro 2 Motion Detection
  • 2 Replies
  • 1422 Views
paisa415
Hi Everyone,
The motion detection system in the camera is not sending me notification when their is movement outside the house. I have set up a zone and that as well do not send me notifcation. How do i fix this? any suggestions?
in regards the Arlo Pro 2 Camera
st_shaw
Master Master
Is your camera inside the house? Motion detection will not work through glass, as it requires IR detections and IR doesn't work through glass. Same applies with zones set.
VancouverBC
Luminary
Luminary
If your camera is setup outside, check Modes > Rules > Edit to ensure you have "Record when motion is detected" and that the sensitivity level is sufficiently high. You can check for motion detection by clicking on Devices > the "gear" icon > Motion detection test. Walk around in area you are doing surviellance and the blue light on the front of the camera will light up when motion is detected. This all assumes your camera is not looking through glass as previously mentioned.
  • 2 Replies
  • 1423 Views
