Arlo Pro 2 Mode connectivity
  • 10 Replies
  • 4819 Views
PhilipQ
In Arlo app, Mode drops device name, leaving a blank page. Must log out and log in to get connectivity for a few minutes before it drops the device name.
10 REPLIES 10
??? Sorry, not following what you're trying to say.
VancouverBC
Luminary
Luminary
How far apart are the camera in question and the base? How many "bars" of signal strength are you getting. At roughly 30 m/100 ft, distance between a camera and the base station, through a wood frame house, in my case the camera is barely connecting to the base station. Can you test by temporarily moving the camera closer to the base station?
PhilipQ
Samsung S7 with a Google log in will show an Armed connection in the Mode tab when first connecting. After the Device or Library tabs are opened, the Mode tab display is blank when opened, no Mode is listed. Google connection on my PC works fine.
PhilipQ
Two cameras have 3 bars, two cameras have 2 bars. The Mode connection works fine on PC, I-PHONE, & Tablets.
PhilipQ
Have made remote Device changes with the Mode tab blank (unable to see any Mode settings or rules)
PhilipQ
The original post was edited by me to explain various Samsung S7 Version 7.0 actions performed in the Device Tab while my Mode Tab connectivity is blank. The Mode Tab remains blank after log-in once any of the other Tabs are opened. I received a post that I listed a successful Solution. This is a problem, not a solution.
Also, my model 4 camera Pro2, VMB4000 base station will not post in the model box above.
That may have been me inadvertently hitting the solved button.  I don't recall if this was the thread but I retracted it and nothing is showing as a solution now.
PhilipQ
Thanks for the reply, I m not sure how this posting works, will Netgear respond to my issue to resolve or to say they are working on a fix?
This is a user forum where we try to help each other out. While there are Netgear moderators here, it may be easier and/or faster to open a case with support here, using the official support link at the bottom of this page (Contact Support) and again on the new page.
PhilipQ,
If you have no issues using other devices (PC and iOS) it sounds like this is isolated specifically to your Android device. Do you have the latest version of the Arlo mobile app installed?
  • 10 Replies
  • 4820 Views
