In Arlo app, Mode drops device name, leaving a blank page. Must log out and log in to get connectivity for a few minutes before it drops the device name.
??? Sorry, not following what you're trying to say.
@PhilipQwrote:In Arlo app, Mode drops device name, leaving a blank page. Must log out and log in to get connectivity for a few minutes before it drops the device name.
How far apart are the camera in question and the base? How many "bars" of signal strength are you getting. At roughly 30 m/100 ft, distance between a camera and the base station, through a wood frame house, in my case the camera is barely connecting to the base station. Can you test by temporarily moving the camera closer to the base station?
The original post was edited by me to explain various Samsung S7 Version 7.0 actions performed in the Device Tab while my Mode Tab connectivity is blank. The Mode Tab remains blank after log-in once any of the other Tabs are opened. I received a post that I listed a successful Solution. This is a problem, not a solution.
Also, my model 4 camera Pro2, VMB4000 base station will not post in the model box above.
That may have been me inadvertently hitting the solved button. I don't recall if this was the thread but I retracted it and nothing is showing as a solution now.
This is a user forum where we try to help each other out. While there are Netgear moderators here, it may be easier and/or faster to open a case with support here, using the official support link at the bottom of this page (Contact Support) and again on the new page.
PhilipQ,
If you have no issues using other devices (PC and iOS) it sounds like this is isolated specifically to your Android device. Do you have the latest version of the Arlo mobile app installed?
